Fan problem | on ElectriciansForums
Discuss Fan problem in the UK Electrical Forum area at ElectriciansForums.net
selby
Hi and thanks for adding me.
I have just fitted 2 x 12v Airflow ICON PIR Timer fans.
Same house 2 different bathrooms.
1 works fine and no probs the other wont turn off.
As soon as i turn on at the isolator it powers up and stays on.
i even got another transformer and module to try incase either was faulty but its just the same.
Any help much appreciated.
Are there lights connected to the switched line?
Are they the same type in both bathrooms?
Are the switches both ordinary mechanical ones?
What voltage do you read between SL & N with the switch off, in each case?
Reply to Fan problem in the UK Electrical Forum area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
Thanks for your advice guys. very helpful
