Went to a farm this week to look at a possible job
had a good look at the earthing arrangement ,
as I always thought that farms were always TT
( and I'm sure I've read a reg in the BRB stating all farms should be TT )
but this one is unlike any I've noticed before
Has a Met with one earth going to a steel band type clamp on cable sheath with a fine braided steel wire(flat) going to another clamp which has a larger twisted unsheathed wire which follows the main cable into the ground
can't see this wire at transformer (25mtrs away) as all the cabling is capped
So is this likely to be TT and this twisted wire the earth electrode ?
Or could it be a TN-S type arrangement with the twisted wire instead of using cable sheaf
Any help much appreciated
