Fault Finding Problem | Page 2 | on ElectriciansForums
Discuss Fault Finding Problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I find fault finding a methodical process, I will however find it very rewarding once problem is found. The other factor that I find confusing is that no work has been completed at the property so causes of the problem have got to be something environmental
I had an IR reading of "0" bet L & N. Opened up two FCU's on the ring with neons, cleaned and checked for gremlins, put back and the reading came up with 469 meg ohms.
The fact that you have 0 between N and E AND L and E leads me to think it may well be a trapped cable that has pierced all 3 cores....or, as said before, water in a junction box. This is not just a N to E fault as your meter has revealed.
Sockets in kitchen cupboards seem to be a favorite on all my fault finding jobs, or hidden sockets behind an appliance.
Had one last week, RCBO kept tripping out. I started by asking the home owner what they were using when it tripped. A lawn mower, so started and removed that socket to find it faulty.
had a good one yesterday in a factory unit. lost all sockets. located fault on socket ring there was a picture hanging on a nail which had peirced line-earth and on top of that a nail holding suspended ceiling edging up which had peirced neutral-earth. both these nails had been in place for at least 12 months!!!! why the rcd had not tripped before is baffling me, after repairs were made rcd tripping times I/R etc all ok.
forgot to say the cables were feeding a socket in a w/c hidden behind the cistern....!!!!
some plumbers really need to hire a brain before plodding off to work.
Yesterday went to a school with floor lights in a canteen area. We only installed them six weeks and already tripping out. 
There's 13 lights and they are all encased in the floor so once I locate the specific one I'm going to have great fun telling them it's coming out. 
IR tests where showing ok, not brilliant for cable installed six weeks ago but passable and continuity was going bonkers with 8890 ohms!!!! Sounds like water damage somewhere.
Reply to Fault Finding Problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Very technical :D
Cheers guys. I was working on the same assumption, but was aware for MF the wagos in wago box were derated 32s, and couldn't find anything to...
