Fault Finding - Ring : Techniques? | Page 2 | on ElectriciansForums
Discuss Fault Finding - Ring : Techniques? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A TDR meter would be ideal as the LCD screen would not only show where the fault is in terms of distance, but would also show how many joints existed in the circuit (a socket connection would be considered a joint) The TDR meter would also indicate if the fault was high or low resistance.
TDR meters are used extensivly is the communications industry and they are not cheap.
Reply to Fault Finding - Ring : Techniques? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
