J
jason_exact
Hi people,
Changed a consumer unit today to a 17th ed split load wylex. Switched on and all was fine for 10 mins then, rcd tripped by the downstairs lights, switched on again and worked for another 10 mins. Meantime i plugged in several different appliance fridge freezer, hoover, toaster etc and each time i did on the same ring it tripped the rcd.
I then took out the downstairs lighting circuit and this meant the ring which was tripping was fine. I then tried connecting lighting circuit again but it was tripping instantly this time.
I have removed all switches and nothing visible loose or nipped.
Can i have some advice on fault finding the lighting circuit? Please keep it step by step and simple im new to fault finding!
Any ideas how the ring is linked to the appliances being plugged in and the lighting circuit?
advice welcome, please help guys!
Cheers......
Cheers......
