Fault on ring circuit (weird) | on ElectriciansForums
Discuss Fault on ring circuit (weird) in the UK Electrical Forum area at ElectriciansForums.net
scotland
Hi there was called to a job with fault finding on a ring 120v on one socket 190 on the other the guy had been doing some work in the kitchen by removing a socket and joint it straight through now it leaves the board as a radial so I had taken one socket of getting voltage on the earth and when I isolated the circuit one of the neutral was live and the rcd hasent tripped either weird one
So is it a ring or a radial???
First port of call would be where someone has been recently working, if it’s a recent fault.
Could be loose cable, faulty socket… anything.
Guy done his own downlights and put screws through lots of cables joined them himself then tiled the floor upstairs so I can’t get access to the joints plus leaking radiator which he had a shock off he’s loves diy but iam not sure it’s for him
Looks like it's time for some big holes in the ceiling and replacing all this guy's wiring.
Reply to Fault on ring circuit (weird) in the UK Electrical Forum area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
