Fault - the smell is like an old "cap" gun | Page 2 | on ElectriciansForums
Discuss Fault - the smell is like an old "cap" gun in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Ok - this is going to sound odd but a good customer of mine has a fault on a lighting circuit - the odd thing is that the smell was like the "cap" guns from my early days!
Any suggestions of what might make that smell (assuming you remember it too)
I've given them a quick temporary fix for tonight so they don't have use of 3 sets of lights .......... and will be going back tomorrow when its light and I have more time
Could be old VIr cable .just thinking about that .the smell i took the grankds to watch the big giants in tels neck of the woods and can you imagine the crowds there.where some s&&t desided to have S&&t inthe crowed and woman in front of us had walk in it and the smell .
the woman in front did not where to look .trying to get it off like trying to get snow off her boots .
A thought - look for signs of green verdigris on bare copper sheathed MICC caused by dampness and made worse by the combination of damp and lime cement. The outer copper sheath may have split/have holes in it leading to the magnesium oxide absorbing moisture - and then the occurrence of some 'low level' arcing and tracking when the cable is energised. The same thing can sometimes happen if bare copper MICC is in contact with damp wood - most wood is naturally acidic.
[ElectriciansForums.net] Fault - the smell is like an old "cap" gun
Thanks for the varied and interesting off topic responses ..
This was the culprit!
Nice to get some closure on a problem and it reported back to the EF. How did you find it and do you know what was wrong with the lamp?
To locate it I used my basic fault finding skills - and in the daylight, one of the tracking light holders had a a "different" smell anddark mark around the inside ... so I started to look at the GU10 LED's more closely which I had removed - and smelling them too!
All I can say is that the GU10 LED doesn't work any more ...
An interesting fault to locate and learn from .........
Reply to Fault - the smell is like an old "cap" gun in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
