silentboarder69
Hi,
I went to carry out a fault find on some heated electrical skirting boards today. It's a new build block. There's a room stat on the wall, and in the ceiling there is a fan system, linked to the buildings vents/air con system. With the fans running, the voltage going to the heated skirting boards is 0v. When I adjust the roomstat up to 30, the fans turn off and the voltage to the skirting board changes to 15v.
Any ideas?
Any ideas?
