Fault with ring main | Page 2 | on ElectriciansForums
Discuss Fault with ring main in the UK Electrical Forum area at ElectriciansForums.net
Surrey
I was testing a consumer unit before upgrading to current standards. (Old re wireable fuses) when testing one of the ring mains continuity i found 38v on the cpc with that circuit disconnected. After carrying out end to end tests on Line and neutral which came back fine. I found the voltage dissapared when I removed the fuse for the lighting circuit?
Any advice on what this would be?
I also have continuity between neutral and line on a leg but haven't had time to investigate further, i e splitting the ring.
Thanks in advance
Thanks in advance
L-n load could be anything, even a neon on a spur. Are you new to testing?
Reply to Fault with ring main in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
