Fault | on ElectriciansForums
Discuss Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
Thewiz
Hello... Got a call from a. Customer saying when ever they plug in there 2kw heater it trips...
So One shal think the heater is faulty. I told them to unplug it and turn the rcd back on.
they rcd then restet... I thought over load may be a issue but she said she unplugged everything. She then plugged all the other items back in and it was fine.
But it she then got another heater and plunged that in put it in leval 2 and pop trips again.
Not been there yet.
Any by thing I should be looking out for when I arrive this week. Not seen this before ever. May be the fault current is to high? Maybe a slight short not big enough to trip the rcd but once the heater is on takes it over 30ma???
Not been there yet.
What happens when they use something else at this socket?
Maybe take a new SO with with you.
Not been there yet.
Do you mean accumulative earth leakage?
Reply to Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
