Faulty proving unit? | on ElectriciansForums
Discuss Faulty proving unit? in the UK Electrical Forum area at ElectriciansForums.net
L
LCD
My Megger MPU690 Proving unit didn't appear to be working, so I replaced the batteries. When I installed the final new battery, the unit made a fizzing sound, all of the voltage lights lit up and then it just died. After this, I tried testing my voltage indicator using the proving unit and nothing lit up on the proving unit.
I've checked the following on the proving unit:
Continuity of wires, pcb for condensation, dust or anything that might be causing shorting.
Any ideas before I throw it away and buy another one?
Reply to Faulty proving unit? in the UK Electrical Forum area at ElectriciansForums.net
C'mon admit it, I won't judge you. This is where the ol' trusty neon screwdriver makes a cameo appearance. You can prove isolation and tighten the...
Mine (Martindale PD90) gets used fairly rarely. You only need one if there isn't a source of power to check the tester still works after...
