Faulty Socket Circuit | Page 2 | on ElectriciansForums
Discuss Faulty Socket Circuit in the Australia area at ElectriciansForums.net
A
AndrewMgan1976
Socket circuit has a 3 gang 13A fused socket on it with a washing machine and dishwasher plugged in to it, but householder has been told not to use both at the same time. Seems to be that when things get plugged in to the socket, it trips after a short time, but not straight away.
IR and continuity are fine, could it just be the socket which is faulty?
Any help would be appreciated.
Found the fault, a socket behind a larder cupboard totally enclosed had an intermittant live/earth fault. Pain in the proverbial but all well and done in the end!
Sorry about the delay in posting the results
Reply to Faulty Socket Circuit in the Australia area at ElectriciansForums.net
Thanks very much - again for your input. It is a moulded-on plug. The first thing I did was change the fuse - which looked, and no doubt (now)...
Assuming you are a novice to electrics? As in no access to electrical equipment. Plug something in to the sockets that you know works else where...
Cbelectrics
C
