Favourite amend 3 board | Page 3 | on ElectriciansForums
Discuss Favourite amend 3 board in the UK Electrical Forum area at ElectriciansForums.net
M
Megavolt
So guys and girls what's your favourite amendment 3 board. Fitted cti, Wylex, hager, British general and MK up to now. MK being the winner up to now but that said there also the cheapest.
I usually fit the MK boards which I find are good value for money. Fitted a bg one last week but wasn't impressed. I couldn't get the factory ferruled line and bus bar in to the terminal on the main switch as there wasn't enough room. Thankfully it was an unoccupied rewire so just used a different bus bar which was slightly thinner.
Has any one fitted an SBS am3 RCBO board? I like the compact RCBO's and the dual busbar (line and neutral)
First one just last week. A breeze and lots of room. The box gauge is a bit thin compared to others and the din rail has a centre fixing screw which means disassembling the rcbos to remove the rail ( Dave supplies the units made up). But generally it gets the thumbs up ( and Dave's service was spot on too).
Reply to Favourite amend 3 board in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
