if you extend the dishwasher lead to the cooker outlet unconventionaly i know / then by use of the 13 amp plug u have discrimination. woollies n ars come to mind
Discuss fcu from cooker circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Unlikely but possible, however I have never in the time I have had the cooker had 4 hobs, grill and oven running at the same time. Usualy at most doing a sunday roast would be 2 hobs at 14.16amps and the oven at 7.5amps. The cable is clipped in an uninsulated ceiling and wall on a run of 4-5 meters. I'm new to this so respect and will follow the advice of if its a risk don't do it. Will have to think of another way, just didn't want to get into ripping tiles ect off if I didn't need to.Are you likely to use the cooking appliances and dishwasher at the same time.
Why not temporarily plug it into the cooker control unit socket and see what happens, if you have no problem you have a solution, go with your original method.Unlikely but possible, however I have never in the time I have had the cooker had 4 hobs, grill and oven running at the same time. Usualy at most doing a sunday roast would be 2 hobs at 14.16amps and the oven at 7.5amps. The cable is clipped in an uninsulated ceiling and wall on a run of 4-5 meters. I'm new to this so respect and will follow the advice of if its a risk don't do it. Will have to think of another way, just didn't want to get into ripping tiles ect off if I didn't need to.
If I have a problem I assume its just an mcb overload rather than cable overload issue? Thanks for your help. I'm new to this forum and everyone has been very helpfulWhy not temporarily plug it into the cooker control unit socket and see what happens, if you have no problem you have a solution, go with your original method.
Reply to fcu from cooker circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
