B
bel83
Hi Guys,
Please could someone throw some help in my general direction?!
We've been rewiring our house under the supervision of a qualified sparky as I want to become an electrician. However he has gone on holiday for 2 weeks and has left me a list of things to get done in his absence. Nothing is connected to a CSU so there's no risk in that regard and he's also checking everything meticulously when he gets back.
We've got three outside lights, all in the same set up (i.e. they're part of the main lighting radial and attached to a switch). He has recommended that we future proof them by attaching switched FCUs to the circuit, in case at some point we want PIRs. They are already wired to a switch as we are going to put the FCUs up at ceiling height.
I'm trying to work out how I need to wire this in. I understand it from a socket, and without a separate light switch, but I'm struggling to work it out from it coming off the lighting radial. I think I have it sorted and then get myself in a muddle. We are using a wago box in the wall space to limit the number of wires having to go out of the house.
The picture is what I think I need to do... but I keep changing my mind between the FCU connecting to the switch or to the WAGO.. because somewhere a circuit line gets discontinued.. and now I'm thinking I need 3 core.. connect the neutral line in the FCU with terminal block, extend a switched live and a com.. do the same in the switch? and again extend the switched live and comm to the WAGO and on to the luminere?
http://www.dropbox.com/s/0xy7rx9204q9bh6/electrics.png
Please could someone advise. And before you all have a go at me for not being qualified.. I am doing this with an electrician. He'll check it all when he's back but I need it in place for him to do it..
Thanks in advance..
Thanks in advance..
