M
Megavolt
Hi all
I have a boiler plant that has a heating and hot water circuit. The problem I have is there is not any zone valves on this system which I would normally use to stop any back feeds.
So the system uses two pumps one for hot water and one for heating.
There is a two Chanel time clock. The hot water output goes via a cylinder stat to the hot water pump and boiler the heating output goes via a room stat to the heating pump and boiler.
I think this can be done with a relay but I do not know how.
Hope I have supplied enough info
Cheers
Cheers
