Feeding a detached garage from a TT system | on ElectriciansForums
Discuss Feeding a detached garage from a TT system in the Australia area at ElectriciansForums.net
R
ryanryan
TT supply to the house, fully rewired and tested with a 17th DB.
I am to supply the garage with a 32a rcd proteted supply via a 6mm SWA.
Is it permited to supply the Earth from the MET or do I need to install a rod?
Reply to Feeding a detached garage from a TT system in the Australia area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
