S
stripes
Hi all,
I have been asked by a friend to quote for a new consumer unit and additional sockets in his home, all pretty bog standard.
However, he is having the original brick built sheds to the outside of his house turned into an bathroom and passage way.
He wants sockets and lights inside the passage way, outside socket, lighting in the bathroom, shaver socket etc.
All the quotes he has received so far are to replace his consumer unit and run a 6mm cable straight from a 40A mcb form the c/u through the houses front canopy (which is be built also) into the passage way at the side of the house to feed a sub main for the new circuits.
I think the supply should be from the supply tails into a Henley block to a Main Switch with cartridge fuse, then run a 6mm cable from the main switch to the sub main, its only a 10m run.
Am I over complicating it?
Would like to hear your thoughts.
