Ferromagnetic problem | on ElectriciansForums
Discuss Ferromagnetic problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
shotton, flintshire
Merry Christmas all
Getting a bit bored of the festivities so i've been thinking about work.
At the office complex i'm testing, one of the steel MEM 3 phase DBs has each phase entering DB through individual coupling, I know this is not allowed in the regs (reg 521.2.1 i think).
i know it can produce heat and eddy currents etc.
What code should i give this?, 2 or 3?
also, what are the extreme effects of this observation?, has anyone got any experience of past problems due to this. Thanks
Reply to Ferromagnetic problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
