Few easy ones, domestic dwellings, smoke alarms, kitchens. | on ElectriciansForums
Discuss Few easy ones, domestic dwellings, smoke alarms, kitchens. in the Domestic Electrician Forum area at ElectriciansForums.net
M
MrTrance
So just to clear a few things up, I work with 10 sparks, all have different answers to these questions.
1. When upgrading a fuse board is it mandatory to upgrade the gas/water bonding to 10mm
2. When upgrading a fuse board is it mandatory to install smoke alarms?
3. When rewiring / new build install, am I right in saying you need a smoke on each floor and a heat in the kitchen (all interlinked).
4. Kitchens, Do I need a fuse spur for washer, dryer, fridge, extractor etc (This one got them arguing).
5. Kitchens, whats the most popular / easy way (new dwellings) wiring cookers / hobs (45A switch behind oven housing? With a socket on for gas in future).
6. Are you allowed sockets / cooker switches in kitchen cupboards
:banghead::banghead::banghead::banghead:
no
no
For all new dwellings, buildings converted to dwellings, loft conversions and dwellings that are substantially extended or altered the Building Regulations require that mains operated smoke alarms are fitted.
no
suitably rated double pole switch above worktop with cooker outlet plate behind cooker or replace cooker outlet plate with an unswitched socket if required.
Yes
what he said, even though it hurts me to agree with a southerner. :toilet:
I just pull Q4 -
Remembering I don't touch domestic nor have for 10yrs .. I was under the impression that if an appliance is built in then a means of local isolation is required without the need to remove the appliance?... correct me if I'm wrong.:confused:
The minimum permitted here for new builds is a Grade D Category LD2 system, which means that you also need a smoke alarm in living rooms. Not sure about England though.
cooker isolator needs to be accessible. inside a cupboard with loads of crap in front of it may not be readily accessible. and it's bad practice to go straight to the cooker without a CCU.
I just pull Q4 -
Not sure of any requirement, think it is best practice. I always fit isolation where an appliance has to be moved to gain access to the flex/connections/plug, either integrated or freestanding appliances.
So do I need a cooker switch above worktop or can I get away with putting it in a cupboard and then 6mm straight to hob?
You can put the cooker switch in a cupboard if you want but its not ideal, you could also come out the load side of the cooker switch in to the hob if you wanted to but again not ideal IMO.
Also for a fan oven would you just mount a socket behind it, would this need a fuse spur? Or could I put this in the cupboard too?
I would mount an unswitched socket behind the cooker with a means of isolation above worktop. You could mount a socket outlet in an adjacent cupboard without isolation above the counter but not ideal IMO.
1 - you must ensure the existing bonding is fit for purpose and not showing any signs of deterioration if you are not going to upgrade it. If no bonding is present then it will of course need to be installed
2- no
3- no requirement to install smokes on a rewire. New builds will depend on the exact details of the building, best consult LABC if unsure.
Reply to Few easy ones, domestic dwellings, smoke alarms, kitchens. in the Domestic Electrician Forum area at ElectriciansForums.net
