FFS, gate contractor, stuck cable. | Page 2 | on ElectriciansForums
Discuss FFS, gate contractor, stuck cable. in the UK Electrical Forum area at ElectriciansForums.net
LeeH
Lincs
Any suggestions welcome.
The gate company has pulled the draw cord out of the flexi conduit inside the brick pillar and left behind a blockage of tape by the looks of it. The pillar has been back filled so no chance of getting inside.
Ive got the bore scope down and you can see the mess.
I’ve tried poking a Klien steel draw cord through and also a 10mm tri rated but it’s stuck fast.
Its about 200mm into the pillar.
It’s my gates BTW...
  • [ElectriciansForums.net] FFS, gate contractor, stuck cable.
Have a word with the client and explain the situation and politely advise you will return to complete the job when the gate company have returned and remedied their mistake.
Or you can resolve the situation on day rate and the client can pursue the gate company for the cost.
I'd give it an hour, just to show willing, first but its a SEP.
Sorted!
A combination of Marvos idea, knocking the brick out and the flexible part of the super rod set pushed in from the bottom end.
I could see no evidence of the conduit collapsing, I think it was just blocked by 2 sharp turns in quick succession.
The automation is now installed, the GSM intercom and gates are due Friday. The builder is coming Monday to fit the brick back in.
No need for TNT ? thankfully.
Reply to FFS, gate contractor, stuck cable. in the UK Electrical Forum area at ElectriciansForums.net
