Fiat punto | on ElectriciansForums
Discuss Fiat punto in the Auto Electrician Forum area at ElectriciansForums.net
Davy-777
Sorry thought this was a help forum im not an auto electrician but this is my query bought an 02 fiat punto for my daughter the headlights are shocking replaced the bulbs to stongest possible then to blue ones with no joy please can someone help
Also not an auto electrician but a few thoughts:
I assume you mean that the headlights are not as bright as you would expect and do not provide enough light on the road.
Initial things I would look at would be are the lenses of the headlights obscured by dirt or condensation, if water has got into the area then they might mist over. Or possibly yellowed with sunlight.
Are the headlights accurately adjusted, they may just be pointing down too low and need adjusting upward.
If the lights are just dim then I would expect a high resistance joint on the cabling, i.e. a loose or corroded connection that is limiting the current, however if it is both lights than it would be before the fuses as they tend to be fused separately.
It could also be that the reflectors are corroded and not reflecting the light . This is the most common problem on older cars.
The 'plastic' chrome dulls and yellows and does not do its job.
EDIT. This is assuming that the charging rate and the battery are in good condition ,and that there are no other electrical problems evident.
Reply to Fiat punto in the Auto Electrician Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
