Deleted member 26818
Only real problem, is choosing a colour.
Oooo thanks Tel I might have to invest5 tread with top platform. having holes for drivers and a couple of receptacles for bits like screws etc.
or get 1 of these. https://www.aladder.co.uk/item-werner_abru_fibreglass_stepladder_lock_in_job_caddy.htmlf
I’ve had fibreglass steps for years now and they are solid feel better on them than I have on any aluminium steps I’ve ever had but they are heavy as hellI am about to invest in some new stepladders. I was thinking of getting Youngman fibreglass stepladders but have been told they are not as stable as aluminium. Also, are they really much safer for domestic electrical work? Aluminium stepladders have rubber insulated feet, which should give similar protection. What do you recommend?
Mine have been on the roof rack for a few years as well the plastic cap on the top has discoloured and the bolts that hold the spreaders have a light rust but they are still pretty much ok I do wash them with the van every week thoughI’ve had fibreglass steps for years now and they are solid feel better on them than I have on any aluminium steps I’ve ever had but they are heavy as hell
so you now have a long john silver ladder?Worth mentioning as well... if you're not careful, it's much easier than you might expect to fracture the legs.
I was moving my steps a few feet when they were open, only to get one leg hooked on a door frame, I didn't realise and carried on going. Went off with a hell of a crack.
Nah, they’re yellow.so you now have a long john silver ladder?
A peg leg?so you now have a long john silver ladder?
I think if you do a risk assessment and method statement you will find you must have fibre glass non conductive ladder for so many scenarios. Personally I always use youngman fibre glass. 4 tread with platform 6 tread and 12 tread all fibre glass.
When I asked the H&S bloke at the factory where I worked if we could get glass fibre steps because the walls of the factory are metal and there’s a lot of water about.
His response was that we should stand the steps on a rubber mat.
