can you help me
in the fica when you operate the landlords switch the light has to come so when you operate the 2way intermidiate nothing should happen as the landlords switch is operated
can you wire your circuit as normal 2 way intermidiate. take a feed onto the landlords switch then just take another switch wire from your landlords to your light or to the switched side of the landlords,
therefore you will have two switch wires at your light
ie
main board to 2 way feed strappers through your 2way int 2 way switch wire from other two way to light, feed from first two way onto landlords then from the sw of land lords to the light
ie
