Jacuzzi ventilation
sythai
Hi Guys
Seeing if anyone can advise on this please.....
We've got a house extension to start soon one of the rooms is a 'jacuzzi room'
Just trying to see what best way to ventilate it would be ?
Thinking along the lines of inline fan on humid-stat. Got a loft above so can fit decent 6" unit.
Builder was chatting to the company supply it and they suggested a heat recovery unit, costing around £2500!
We need to get it right so if it does need heat recovery unit (assuming this same as MVHR) then so be it.
Thanks Sy
if the jacuzzi has its own room then ,by putting in a 6in fan could be ok ,but you will have to work out the moisture that is taken when the lid is taken off if it has one ,has the room got a window in .
Thank you for the reply.... there's no windows for this room.
We have to get the 1st fix before jacuzzi is in place. So wouldn't be able to check it this way unfortunately
Heat recovery unit would save money in the long run, assuming it stays working long enough, and is the 'environment friendly','green' solution, but it'll take a while to get back £2500.
