Filling in switch fuses on a certificate | Page 2 | on ElectriciansForums
Discuss Filling in switch fuses on a certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's not my idea of doing things...…..need a single phase supply so pick up from a local 3 phase circuit point. It should have a separate supply as a single phase circuit....BUT, which regulation gives non compliance?
As regards the DB, it's been taken from a final sub circuit so what is the difference between that and a fixed fused spur.
I wouldn't treat it as separate DB with it's own schedule but make a note on the cert.
Edit. What about rcd with the socket?
when and why ?
Isn't that what we do with a DB??? To ensure protective devices will operate within required times???? Fuses are the same??
As regards the DB, it's been taken from a final sub circuit so what is the difference to that and a fixed fused spur.
I wouldn't treat it as separate DB with it's own schedule but make a note on the cert.[/QUOTE
Thankyou
Long week
What if 40amp supply to a switch fuse. 63amp fuses in switch fuse.
Already coded
If I have understood correctly and the circuit is fed from a 32A MCB, then surely the 32A fuses are redundant as they dont add any aditional protection, and I would have thought the MCB would always operate first (unless maybe its a D curve?)
Reply to Filling in switch fuses on a certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
