Finally joined. | on ElectriciansForums
Discuss Finally joined. in the The Welcome Forum area at ElectriciansForums.net
Leeds
Hi.
Your forum has always been a valuable source of info when needed up till now. I've finally joined as I'm at a point where I may need to ask advice.
I've moved from the midlands to Leeds. I have been a rope access tech for the last 6 months, having been an arborist from college 10yrs prior.
The nature of rope access work means I'm working away almost constantly. This is proving hard for my partner with being in a new place where she knows no one. I've spoke to my employer and they are happy to have me work a shift on and a shift off (11 day shifts).
This is fine as I've already found tree companies that I can fill my shift breaks with. The thing is, I really enjoy electrical work. Before starting the rope access work, I put myself through college and gained the following electrical qualifications; City & Guilds 2330 Levels 2&3, 2382 17th Edition Regs and 2392 Inspection and testing with straight distinctions.
Now seems the perfect time to start swapping out the tree work for electrical. I have some job hours as I've been helping a friend on domestic jobs when I'm free. I also have some tickets; CSCS,ECS,MEWP,First Aid.
My plan was to start calling companies and sole traders around the local area and see if any will have me help out a couple of days a week at a very basic wage until I've proved my worth enough to get a steady enough position to start working on a NVQ.
Am I heading in the right direction? Any advise is greatfully received!
Giles.
Welcome to the forum, you are heading in the right direction, make sure you are up to date with the current version of BS7671.
You will find it difficult to find someone to employ you (for any amount) for short periods, but do keep trying, good luck.
Thanks Richard + others for the positive replies, I have the latest regs book with the 1st amendment: 2011 along with the small green & yellow guide books.
I'll just have to see how it goes. I'm very open to compromise and "there is more than one way to skin a cat"!
Reply to Finally joined. in the The Welcome Forum area at ElectriciansForums.net
Welcome to the forum! When are you planning on starting your level 3?
Welcome back, What was your old user name?
