Fire alarm cables - can they be painted | on ElectriciansForums
Discuss Fire alarm cables - can they be painted in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
are you sure?
you could use pink if the customer was willing to pay for it,red is recommended but as long as all the fire cables are red or all of white or any other spec'd colour it complies as long as its not the same colour as the general electrical services quote as per fire alarm design guide
Yes they can be painted, and yes white cable can be used.
Although generally it is used for the supply to the fire alarm control panel, and everything from the panel is in red.
so what if i am using red fp on cable tray then branch off the cable tray to go into different rooms, surface clipped. The ceilings are white,so if they are painted white the cables will be 2 different colours (red on tray, white on ceilings) is this acceptable?
Also what is the minimum distance a smoke head should be located from a luminaire?
imo that would be no different that putting than bit of the run in white trunking your not physically changing the colour of the cable if you know what i mean,how close are you putting it
Reply to Fire alarm cables - can they be painted in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
