Fire alarm detector help.... | on ElectriciansForums
Discuss Fire alarm detector help.... in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Leeds
Hi guys, I'm hoping one of you will be able to help me with this, i have had a client send me a couple of picture of existing detectors that need changing and for the life of me i cannot remember what make/model they are!
[ElectriciansForums.net] Fire alarm detector help....
Thanks Again!!
They look like they could be a "menvier" but hard to tell from pics, is it a conventional system? Apollo 65 series are compatible with most systems you'd just need to get the base and detector and replace both.
on closer inspection of the pic, they look like they've got a brand name on the bottom, can't make it out though ask for a pic from the bottom or hedge your bets and turn up with Apollo 65.
99% certain the one on the sounder base is a Morley Vision. Although you cannot read it from the pic I lay money it has VISION written on the head.
Reply to Fire alarm detector help.... in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
