Fire Alarm Systems | Page 2 | on ElectriciansForums
Discuss Fire Alarm Systems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Plus , as you say , it resets after 5 seconds . So you gotta run downstairs super quick to see if the panel has responded
I understand what your saying, but fire system are built to monitor the detection circuit, so if no fault is showing on the zone, then it has no o/c and no c/c. And if when tested the led is lite. then proof of supply and cable have been proved
Oh right , fair enough , if thats the case then i will do silent tests from now on , obviously i'll do a sounder test in each zone to prove they work first haha . cheers tazz . You are indeed the man
Tazz defo the man here Joe. I learnt the hard way!!!
Would also like to make a small point that on some addressable systems you'll be able to find a log inside the panel delict of what has gone off while in test mode so you could confirm which have definitely gone off for your own piece of mind (obviously not on conventional systems).
Some addressable systems also have a printer on the front - such as an Advanced panel this also confirming a fire state.
Reply to Fire Alarm Systems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
