fire alarm | on ElectriciansForums
Discuss fire alarm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
leekemp85
how often does a fp 200 need to be p clipped, is it every clip or can a p clip be used in between plastic clips also with wire suspension system could how often would I need to use a metal tie wrap
many thanks
many thanks
Installed lots of fp200 in hospitals and we always have to p clip every 250mm on solid walls (no plastic and on tray or basket metal zip ties every 400mm hope this helps :)
many thanks
Metal clips 250mm horizontal, 400mm vertical.
If in plastic conduit then saddles must be metal.
If in plastic mini trunking then cable must be clipped with metal clips inside the trunking.
Cable below 2m should be mechanically protected.
All BS5839
Cheers, Ron
Reply to fire alarm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
