vbyrne
Hi all, I have been called out to a fire alarm that has two faults on two different zones, the problem is that there are some devices that I can not find . new plaster board ceilings have been put in and stud walls have been built over the top of the alarm. What I am going to do is go right back to the panel and start tracing cables as far as I can then disconnect the cables that I don't need if it is in the middle of a circuit I will just run a new cable in i need to do a lot of tracing would a tone generator work in this situation
