OP
bugsy
Only BPG suggests downlighters with integral protection, and I wondered hw the flower pot brigade got round the situation
Discuss Fire Hoods and Fire rated D/lights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
You can also argue the fact if you have tongue and grooved boards upstairs
I think I know what you mean but after studying the best practice guide I have it down as thats the way.
After all those guides are supposed to be leading the way to new up and coming regs.
I think the moral here is if its safer then its better practice.
Just a my thoughts and thanks for the input.
As far as I can make out reading it sideways much the same.
Best Practice Guides | Electrical Safety Council
Fire rated fittings or fire hoods are only required when compromising the fire resistance between fire compartments.
A standard two storey house is one single fire compartment so not required.
If it has an integral garage with a room above then the garage is one compartment and the house is another. Should you foolishly want down-lighters in the garage then fire rated fittings or hoods would be required.
Aurora Sola Range , a solution to the problem -
Footnote
Don't piddle about with cheap materials it costs you more in the long run!
Reply to Fire Hoods and Fire rated D/lights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
