Fire hoods for downlighters | on ElectriciansForums
Discuss Fire hoods for downlighters in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Steve D
Hi All,
I've never fitted any downlighters before and I've been asked to fit some. They're not fire-rated by the look of it and they are to be installed in a bedroom where there is just the loft above it.
What are the rules regarding fire hoods? After scouring some older threads, it seems to indicate that if there is just a loftspace above the light then fire hoods aren't necessary.
Cheers
Steve
Ask yourself is the ceiling you're cutting into classed a fire rated. If it is fit hoods or fire rated fittings and if not then they ain't required.
I think most fit fire rated as standard and I always like to provide as much protection as possible when it comes to preventing the spread of fire.
Considering we should fill holes where cable passes for that reason.
Make sure you keep the insulation at bay and provide some way to ensure that it does not fall back on to the fitting.
I always fit fire rated nowadays, however, they are not really required to be in a normal domestic dwelling, unless they are fitted in an integrated garage ceiling or in a ceiling with a flat above for eg.
Just a thought
I believe standard plasterboard has a 1/2 hour fire rating If we fit a non fire rated product & there is a fire which spreads to loft who will have made the situation worse ? Surely the extra cost is worth it ?
Just a thought
The IET commisioned research on the effects of downlights and fire integrity
The conclusion of the research was that they have no effect whatsoever on the spread of fire in a normal domestic situation
The joists themselves form a fire compartment and the installing of a non fire rated downlight was nil on the spread of the fire
Its available to view on the IET site
Reply to Fire hoods for downlighters in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
