Fire hoods for downlighters | Page 2 | on ElectriciansForums
Discuss Fire hoods for downlighters in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Fire rated don't only offer protection against spread of fire but also acoustic insulation. Also reduce dust buildup on rear of lamps. I now never fit un rated
I always fit fire rated nowadays, however, they are not really required to be in a normal domestic dwelling, unless they are fitted in an integrated garage ceiling or in a ceiling with a flat above for eg.
Not required in a normal domestic dwelling?!!! What is the Reg on this, please?
Sound advice - just remember to make sure there is no insulation covering usually at least 100mm space needed
Reply to Fire hoods for downlighters in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
