Commercial premesis shop front/ sign lights. These are all LED illuminated not neon high voltage type. Is a firemans isolator for use only with neons lighting where high voltage exist or any frontage lights??
Discuss fire mans isolator req or not? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
This would be down to a risk assessment.....firemans switches are not just for neon signs, they are used where a risk is identified on the premises....in a petrol station they would be manly used to isolated pumps, and external lighting, to eliminate a source of ignition. Neon signs where classed as high risk due to 3kv voltage, but the potential was low.....led signs have low voltage but high potential of 20amps or more at 12v, so the source for ignition imo is still there. Conclusion is what are the premises be used for and what are the risks..?
Reply to fire mans isolator req or not? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
