Fire Panel for HMO building | on ElectriciansForums
Discuss Fire Panel for HMO building in the Talk Electrician area at ElectriciansForums.net
Sean1972
Hi,
This is the first time I'm posting a question so I hope its in the correct forum.
I'm required to fit a fire panel system in a two story Victorian house which has 6 rooms and a kitchen.
Does anyone know if I should use a 2 zone system and split it between the two floors or an 8 zone system where every room is in a dedicated zone ?
Any input will be apperciaited.
Regards,
Sean
Before doing anything, the application for HMO licence will state exactly what is required, fire alarm, doors, seals, extract vents etc .....leaving application till last will cost a lot of money ripping out and correcting
Reply to Fire Panel for HMO building in the Talk Electrician area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
I've looked at the fire assessment from the last HMO I did for the same landlord and fire assessor, the risk assessment is pretty worthless, it's...
