Guest viewing limit reached
I think we can get tangled up in why the regulations were brought in and also the scope and scale of the problem. if we consider a room is a compartment designed to keep occupants safe then the door, walls and ceiling make up the compartment and these are the structural elements that must last as long as possible, so doors ceiling and plasterboard walls in a new build all 30 minutes protection. Take the same in a twenty-year-old block of flats with concrete walls ceiling etc then the wiring could be in trunking at the high level fixed to the concrete with plastic plugs. Because of the difference in heat, the trunking can start to fail and collapse into the cooler zone below where the occupants are escaping or the fire brigade could still be operating and then entanglement becomes a real issue and a cause of death. Another thing we have found is where the heat (hot air) can travel along trunking and pop off the lid a long way from the fire and stop evacuations due to entanglement this way. Long lengths of steel are liable to collapse from stress and twisting due to heat so likewise, we protect with twin layers of fireboard to give some protection. In a standard house, the risks are much lower than in blocks of flats and commercial buildings because of the different building methods and the numbers of occupants.
Disagree.
Half baked, ill thought out regulation with no guidance
That's why we are discussing this
If clear instruction was given tio justify, and explain, plus clear guidance on interpretation then it would be ok
We have none of the above.
in some ways, I think you are right NICEIC and NAPIT along with all the other bodies do not give sufficient information to electricians as to why this is needed or how to resolve it.
As an ex spark and safety professional, I put myself forward to try but I also designed one of the first clips to resolve this so I am biased.
All I can say is "metal clips everywhere" will undoubtedly save the lives of both firefighters and persons trying to escape fires.
If they gave detailed information what we expect to be given to carry out our works then they wouldn't make millions off the back off guidance books etc, I suspect the industry is deliberately making some regulations ambiguous as it leads to a side market that makes them a fortune. What niggles me is the fact we pay such high costs for these regulations then spend months trying to decipher some of them, it isn't because we are thick or inexperienced it is because those that create these regulations are sat at a desk and not out in the real world imho and as I suspect that creating a regulation that is clear and concise and easy to interpret will ultimately lose them millions in profit.
I couldn't agree with you more, they don't discuss commercial and house rewire /newbuild separately. They give no reasons for doing things they just state what they want and the sparks are left floundering. The language in the 18th edition makes it even more complex. I am on here and a lot of other places just to try and give support where I can, so always willing to help on here where I can.
To be fair this isn't just the BS7671, it is across the field of regulations be it the Fire regulations or Machine code both of which I use a lot, I don't expect the regulation to spoon feed all situations as that is impractical and impossible, what I do expect is enough clear guidance that one can then understand what the regulation is and why thus can use this to make a informed decision on situations that are not really covered or exampled by the regulations.
Agreed and the Building Regs are the worst of the lot, I am putting a forum similar to this on the clips website purely to answer questions like we have had on here. How can it be with such a long run that the knowledge out there is minimal and sparks are struggling to find answers?
Too factors, more ambiguity in regulations and dumbing down over decades of tutoring, when I did mine in the 80's we left college understanding why regulations existed, not just to parrot them, nowadays the system has been dumbed down so much to allow for poorer educated school leavers and for political gain of whichever party is in government, students passing colleges ticks voters boxes hence dumbing down the whole process has political gains... this is also why the general education system now produces kids that cannot do basic maths.
You may be right, I did a five-year apprenticeship that has now been slashed.
I must say I do a lot of asbestos awareness and fire training along with Manual Handling etc and the younger sparks seem to be very good. All of the apprentices placed with me have gone on to shine so I think the skill set is still there maybe its the way they are managed that has changed because I see a lot of bored youngsters on site who knows?
Something like this would clear up the ambiguity:
"Cables installed in areas considered escape routes need sufficient protection against fire. This is specifically relevant where cables are above suspended ceilings and / or attached to walls in combustible capping or trunking.
Such additional protection is not required if cables are run perpendicular to the joists and above a plasterboard ceiling.
Should the cables be run along the side of a joist above a plasterboard ceiling for more than 1 meter, then suitable clips resistant to fire should be used."
Tin hat on
The building regs produced by the DCLG are completely hopeless, open to interpretation. Its not answers people need its less ambiguity.
Compliance is rarely checked
Its not just sparks .......... its all trades who struggle ................
So one simple line turns into an essay! Imagine that throughout the regs! It would end up being 800notes at that rate!
If the regs end up too prescriptive then it produces more problems than it solves. If for no other reason, than there is always more than one way to skin a cat!
In the eyes of those who write the regs, the suspended ceilling problem is doubtless non existent, because obviously all cables are run in tray or basket....
for me as long as they are perpendicular so pass through the joists then this is perfectly understandable and can be followed by everyone see no tin hat required.
I don't understand how H & S like me do site audits and never check what is inside trunking I do every time and explain why! what about NICEIC visits?
Why not have one tick box on the certificate "all areas protected" none of this is rocket science but nothing is done.
I also do H & S visits for insurance companies if the cert had a tick I wouldn't check because the spark has confirmed he/she is competent and has done the work correctly. perhaps I just expect too much?
Regs simply put the onus on you..and if you expect step-by-step guidance then you will get the same response as DIYers get on here...
Question: If I install cables in this location, is there a risk they might cause an obstruction in the event of fire?
Answer: Yes, they might. Thus, I will install them, to the best of my ability and with the appropriate fixings, so as to minimise that risk.
If I doubt my ability...to assess or install...then I will seek expert advice, and having sought and obtained that advice, or having assessed and made my own decision, I will record that so I may answer any questions at a later date.
If I am unhappy with that, I will not install.
Nuneaton
Fire rated clips - any suggestions?
Security Alarms, Door Entry and CCTV (Public)
Mark Goddard,
pirate,
