Fire rated downlights or not | on ElectriciansForums
Discuss Fire rated downlights or not in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
B
bignod
Hi
I have been to look at some down lights in a basement flat that are not working. There is a mixture of MR16 lv lights and GU10,some of the fittings are fire rated approx 10 of them and another 12 that are not. There is a shop above the flat with another flat above that.
So my question is should the fittings be fire rated or not
Many thanks
It would depend on the ceiling itself, are these fittings in a lowered or false ceiling is the original flat ceiling correctly fire rated and unbreached, regardless of whether thyou could use standard fittings, IMHO always fit fore rated ones as they are now cheap enough so really struggle to see anyone giving a plausable excuse not to.
Reply to Fire rated downlights or not in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
