First board change.
Hi MDJ,
I should have clarified earlier, it was in my work's stores area, and it was at the first floor level, but out past the guard rail of that floor area, so any time a fuse had to be changed/inspected or isolated, you had to reach out over the staircase to access the board. The join between the boards were three 32mm couplers. Hope this clears it up, apologies for confusion.
This photo shows the location of the old board.
