First edition of wiring regs 1882! | on ElectriciansForums
Discuss First edition of wiring regs 1882! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Just found these and intend to frame them in the office!!
[ElectriciansForums.net] First edition of wiring regs 1882! [ElectriciansForums.net] First edition of wiring regs 1882!
So long as you do not start to follow them!
Things were simpler once methinks.
Just 2 pages for the entire regs.. A wishful thought!
I like point 10.. The employment of gas or water pipes as conductors for the purpose of completing the circuit should in no case be allowed.
i do like the splice though
with solder you would need a tractor to pull it apart LoL.
i was given a wiring book based on the nec codes back in the late 60's
a bit of lite reading but tha bad part was the book has a slightly musty odor
(must have been damp at one time or another)
You want to see some of the crap that’s still OK in some states of the good old USofA?
The soldered joints are breach, married, britannia and scarf. I was taught how to do them all.
And for industrial
And for industrial
actually wiring like this is not acceptable and if inspectors see any of it the have the meters pulled.
Reply to First edition of wiring regs 1882! in the UK Electrical Forum area at ElectriciansForums.net
Do some of the free online tests. Get used to using the book. After doing this I passed mine easy enough.
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
