First Job estimate price check | Page 2 | on ElectriciansForums
Discuss First Job estimate price check in the UK Electrical Forum area at ElectriciansForums.net
Rugby
I am in the process of doing my first quote and wanted to see what people thought in regards to my price as this is my first one since becoming registered so it would be great to see if I am in and around the right lines or whether I am way off the mark.
The job is as follows:
-Fitting three double sockets to an existing ring final and chasing the cables in the wall horizontally between them (I know not best practice but the client has concrete floors and is really against surface trunking).
-The chases will be about 3 meters either side of the existing socket, il fit some conduit for a bit of extra protection but the circuit is protected by an rcd and the cables will be in the safe zones so won`t need to go too deep.
-Some AV work chasing in and fitting 2 HDMI cables, a USB, coax and a Network cable to modular face plate on a wall from behind where the client wants the tv mounted to where the sky box/router is. (about 3m in total end to end).
-Making good by bonding and skimming all the chases
-The walls are all masonary.
-Tested and minor works cert issued.
I`m looking at it as a full days work possibly a day and a half with the plastering and fiddling with the coax and network cable so was going to charge ÂŁ220 labour + Materials.
Does this sound about right or is it too under/over priced? If any of you experienced guys could offer some advice it would be greatly appreciated, feels a bit alien to me at the minute with it being new and this forum has been really helpful so far with advice.
Reply to First Job estimate price check in the UK Electrical Forum area at ElectriciansForums.net
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
