Guest viewing limit reached
N
nick182
Hi guys,
Ive officially been givin my first ever job since leaving college and today it wasnt as i thought it would be..
I have been quoted to do a job for a new boiler. :shocked:
can a person who has completed level 2 n level 3 2330 do this kind of job or do i have to refer it to someone else?
I hate to turn the work away.
If you're changing out the CU you'll be notifying that under Part P anyway so in the event that you're doing the boiler too just change the CU, test everything as normal and write out your EIC. Then hang fire on notifying the job until the boiler is in and you've wired up and tested it then notify it all at once. The notification only needs to be done when all work is complete however make sure you have test results for all circuits before you leave them energised after each part of the job.
Dunc. If you're not with a Part P scheme then you need to notify before work starts (Approved Document P page 11 paragraph 1.21)
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADP_2006.pdf
first job.. new boiler? what do i do?
Australia
nick182,
topquark,
