Fishing cable in ceiling | Page 2 | on ElectriciansForums
Discuss Fishing cable in ceiling in the UK Electrical Forum area at ElectriciansForums.net
Steve T
Newcastle
Hi
I’d like to install some lights in a cabinet, and the easiest way to power them is from one of the downlights in the kitchen, so they would be switched on by the same switch as
the downlights. To run a cable from the downlight to the cabinet, the easiest way would be to fish it through the ceiling with a rod, under the joists (they run perpendicular to my cable route)as there is a gap between them and the plasterboard ceiling.
Would this be an acceptable method of running the cable in the ceiling?
It would be the easiest option as the floor above is carpeted and is t&g chipboard.
Thanks for any replies
....but, if it's perpendicular, its running vertically down the wall......or in the middle of the room, maybe?
Are we talking parallel, by any chance?
@ipf
perpendicular
ˌpəːp(ə)nˈdɪkjʊlə/
adjective
  1. 1.
    at an angle of 90° to a given line, plane, or surface or to the ground.
If they were parallel they would be going the same way. So if the joists are running east to west, the branders or cross batons are running north to south.
Just seen the photo....fair do's
Looks good - fishing a bit quicker than cut, drill, feed, fill etc. May I suggest leaving additional cable so it's nice and loose in the ceiling space.
Reply to Fishing cable in ceiling in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
