Fitting a double dimmer switch | Page 2 | on ElectriciansForums
Discuss Fitting a double dimmer switch in the Lighting Forum area at ElectriciansForums.net
My suggestion is - whichever switch is the one you no longer need, or doesn't do anything, remove that feed to the lamp from the old switch and insulate the end of the wire with a Wago or similar, That's not to be used any more.
Then for your two dimmer switches, connect the live feed presently linking the switches to L1 on each dimmer.
Then connect the dimmer tilda ~ terminals to the remaining two lamp feeds.
Sort of like this (not my art!) - blue and yel representing the two lamp feeds, stating the obvious!
Hello, Thanks for your suggestion.
Sorry, Had an urgent call from a neighbour. I have wired the switch a different way from your o. Something is wrong as only one light is working.
I will use your method an see if that works.
Thanks for your assistance.
method I used is as shown.
Not as neat as yours but your comments would be welcome
You've drawn 'COM' on the diagram. Is that what is actually marked on the dimmers?
Do you have a leaflet with the dimmer showing how it is to be wired?
I think putting the power into the dimmer 'output' is wrong!
Finally, can you swap the blacks over and see if the behavior of the lights swaps correspondingly?
OK. Thanks.
Doesn't seem to matter which way round your dimmer is connected.
Both ways are shown as valid. Sorry - red herring.
So to find out what's going on with your non-working dimmer, can you try putting the working light on it, just to check if it's the dimmer, or the circuit?
I think you need to verify you have the correct two wires. Mark the supply wire so you don't mix it up and connect all three wires together, if both lights work you have the correct wires.
Reply to Fitting a double dimmer switch in the Lighting Forum area at ElectriciansForums.net
  • Solved
As Freddo has said above, that's an intermediate switch, which will be wired with two other two way switches. Your dimmer switch is a two way...
Oval knockouts, so 16mm. Just as well the plaster was laid on thick.
