fitting a pir near roadside | Page 2 | on ElectriciansForums
Discuss fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
multimick
ormskirk
got a job fitting a pir near side of road (4 metres away) to contol 2 led floods any tips to avoid cars or pushbikes setting it off ,i can point it down and buy one with sensitivity control but any other tips please
It would've triggered if they'd jumped through the window after smashing it, though.....:rolleyes:
Exactly. That's my point. It takes a heat signature to activate it. They are not motion sensors. They are heat sensors. You could place a lamp in front of a PIR and drag it about. It will not trigger. Leave it where it is and just switch it on and the heat from the bulb will trigger it. Try it.
That photo looks staged.
The photo was "staged". I put the brick there and took a picture of it for insurance purposes. Staff had moved it and started to clean up by the time I got there. But here's the glass and here's the window.
[ElectriciansForums.net] fitting a pir near roadside
As far as I understand it, a PIR sensor has a spread of sections that are sensitive to heat, generally approximately human body temperature, though any wide range of heat source will work and the received light is focused onto the section.
Each section is looking for a change in heat reception, i.e. a presence or absence of heat, if this change occurs from one section to another, or repeatedly on one section, depending on the algorithm used by the manufacturer, then the PIR will trigger an output.
A moving incandescent lamp should trigger a PIR as it will be sending out a wide range of IR wavelengths, similarly if the lamp is switched on the detecting section will register a change in temperature as the lamp heats up from cold and as it passes the temperature range and so will also trigger.
You silly sausage, the leaves grow back in the Spring. Watch a bit more Gardeners World, you'll get there.
but the beer in my glass won't grow back. i have to go to the offy. maybe i should plant a beer tree in a barrel.
Reply to fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
