The consumer unit was only installed last year to 17th edition Amd 3 & now the customer wants a SPD fitted after a friends £2k TV got fried by a lightning strike.
As MK do not make SPD, can you fit another brand of SPD in the consumer unit.
I know the rule about mixing brands of MCB/RCBO in a consumer unit, but does this apply to a SPD.
I believe the rule you talk of applies to all CUs and associated equipment, unless you have manufactures assurances that to mix and in the particular instance is OK, why not fit a Type 1 SPD at the origin of the installation 534.1 table 3.7.3 OSG Page 41
Unfortunately there is no space to fit a separate SPD, as it's all in a cupboard with the meter above the front door.
A type 1 SPD is for installations with an LPS
A type 2 would be more appropriate
Fitting a SPD to MK Consumer unit
philipbg,
philipbg,
