Fitting bolt in fitting | on ElectriciansForums
Discuss Fitting bolt in fitting in the UK Electrical Forum area at ElectriciansForums.net
Improver 007
Hi all I have an outdoor wall light which is bolted from behind. Then a decorative nut threaded on the front.
As I push the plate on the bolt goes through leaving nothing for the bolt to grab on to one side as the wall is hollow on the back.
Such an easy job turned annoying lol. Anyone have any tips before I throw the light
The trademark features of a light fitting designed by a non-tradesman.
Sticky tape, blue tack, putty.... anything just to hold it in place
Cheers I can’t believe the fiddle with this fitting. Wiring takes five mins and then I’ve been messing about with this poxy bolt which keeps disappearing as I got to bolt up 😂. Blu tac may actually work well.
Thanks all
Thanks all
Don’t worry we all hate those fittings!
secure the bolt head with some tape or gorilla glue. it's supposed to be captive but relies on contact with the wall to stop it falling out.
Reply to Fitting bolt in fitting in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
