fitting dimmer switches | Page 2 | on ElectriciansForums
Discuss fitting dimmer switches in the Australia area at ElectriciansForums.net
M
mk1vanman
as title really, i am replacing the two switches in my dining room with dimmers, but am not sure of the correct way to connect them? on the dimmer there is a wavy lne then an L1 and an L2, what do i connect to?
cheers!
Just do a Mr B&Q and put all the red wires in the same hole....
Don't do this. I recommend you call a local Part P registered electrician who will do it for you. Electricity is dangerous stuff, if you aren't sure what you're doing, don't do it. Considering all the guys on here are trained and they can't decide between themselves, someone who isn't trained hasn't got a chance.
love your answer made me chuckle
Reply to fitting dimmer switches in the Australia area at ElectriciansForums.net
  • Solved
As Freddo has said above, that's an intermediate switch, which will be wired with two other two way switches. Your dimmer switch is a two way...
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
