Fitting Hive 2 to a oil boiler in Spain | on ElectriciansForums
Discuss Fitting Hive 2 to a oil boiler in Spain in the UK Electrical Forum area at ElectriciansForums.net
jedder
Hi all,
Can you help,
I have bought a Hive 2 active heating (heating only version) to replace the thermostat we have in spain,
Its an oil combi boiler (Tifel - Eurofel 40 See pic)
The exising thermostat / control only has 2 wires goin to it from the boiler (see pic).
Can someone give me an idiots guide to point me in the right direction of wiring this so that the hive 2 controls it.
thanks guys,
Jedder
[ElectriciansForums.net] Fitting Hive 2 to a oil boiler in Spain
Might of been better to get a nest.
The back plate you have shown does not go where the thermostat is. You can put that next to the boiler.
The thermostat connects through your broadband connection
Don't put that back plate on where the thermostat is though. That just wants to go next to the boiler. connected like Lee said. The thermostat just runs off batteries and recieves a wireless signal. Can be fixed anywhere on the house (within reason)
Reply to Fitting Hive 2 to a oil boiler in Spain in the UK Electrical Forum area at ElectriciansForums.net
R
Hive thermostat multizone help Can anyone help me. I have just moved house and we have a boiler with a separate hot water tank and then 2...
Rick1980
R
I cannot give the answer. that said if you google it and download the PDF it may give you the answer.
